This is the fuel pump assembly for the ES, that metal section I think you're talking about is part of the pressure regulator. What you can try doing to see if the pump will hold pressure and not just drain backwards into the tank is take a piece of clear hose a few feet long and attach it to the pump output, power up the pump and allow the hose to fill up with gas and block off the end, see if it holds the fuel in the hose. If it just drains backwards back into the tank, then the check valve in the pump is stuck open or there's a crack in the assembly somewhere. The fuel pressure should hold for at least 5 minutes. Since you don't have a pressure gauge, I think you'll find the fuel is just running back and not able to build up pressure. Plus, you need to really get the correct pump in there. The ES pump should be putting out 45-50psi in just a few seconds.
An amp clamp is for measuring amperage(current) on the fuel pump or any circuit.
This is a current waveform from the Ignition coils from my truck (2nd diagram), this is from the main power feed to the coil pack. It's a V6, so each cylinder is firing. You can see an issue with the 1st coil firing, that negative amperage spike. This is a quick way to find failing or failed components.
The next one is a relative compression test on my Honda CRV. Same idea. If you look closely you can see 2 cylinders that are lower than the other 2. Bad head gasket on this one.
May 14, 2023 at 6:55 PM
