Hi and welcome to 2CarPros.com.
Since the no fuel issue happened after replacement of the regulator, I need you to recheck your work. Something is causing the issue whether it be a missing o-ring, assembly incorrect. I attached an exploded picture of the component. Take a look at it and confirm everything was reinstalled correctly. If it is dropping the pressure too low, it will not start. Pay attention to make sure the fuel pump is turning on.
Let me know what you find.
Nov 11, 2018 at 4:15 PM
