Hello, I've recently acquired this car as I had my previous car repossessed. It had been sitting for about 2 years because the previous owners claim it just stopped turning over. The car will crank and ignite every so often. But it will not ever turn over. I have already replaced the distributor, spark plugs, spark plug wires. I have also made sure that my ignition coil is good and ignition control module is also working. At this point I was searching for the crank sensor and could not find even a plug on a harness for it. It should be around the harmonic balancer but it was no where to be found. It has fuel, spark, and I have the throttle body completely open with no air filter, so it has air. I have also tried turning the harmonic balancer to every position imaginable and the dot always lands on the same spot after cranking. Any other ideas would be great. I need this car to be running relatively quick because it is my only vehicle. Thank you in advance.
Feb 23, 2020 at 11:21 PM
