Bought this car cheap had a broken timing belt. Put on new belt with all marks lined up tried to crank to see if would run before I reassembled everything it just cranks over and doesn't start. I have replaced crankshaft sensor, camshaft sensor and temperature sensor. Fuel pressure is 30ish, has spark. Has stupid valet parking thing I unplugged it and removed just in case it was the issue. Tried to check for #1 piston to be top dead center but crank shaft timing mark won't line up when it is. Did i mess up on the timing belt? Any help would be great. Thanks
Mar 7, 2019 at 1:09 PM
