I have a restored 1956 Chevrolet truck with a small block, supposedly rebuilt. The motor began smoking out the rear side exhaust. I ran a compression test and all cylinders were 135-145 and the spark plugs all looked good. The truck ran good, didn't heat up nor any fluid leaks. Thinking it was possible a blown head gasket I removed the passenger side head a found a damaged head gasket and water in 1 and 7 cylinders. Since I had the motor tore down I decided to remove the driver side head and to my amazement I found water in #8 cylinder yet the gasket was in good shape.
Know I confused. How could water be in both sides. The intake and head bolts all seemed to be torqued down.
Any help would be greatly appreciated.
Jun 24, 2019 at 12:14 PM
