accelaration problem
2005 OPEL CORSA
170,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
RAHIEZ
Hi guys, new here. i wanted to find out if you can give me an idea on why my car listed above model C is not performing like it should. it feels as if something holding me back (sluggish), and it is a bit heavy on fuel. I recently done the head gasket and service what could be the problem i read a lot of the fuel pump relay?
Mar 16, 2017 at 2:58 AM
It sounds like the MAF sensor has gone bad which is a common problem. But first check for trouble codes and then you can try cleaning the sensor first but that sometimes does not work.
and
https://www.2carpros.com/articles/mass-air-flow-service
and
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
and
https://www.2carpros.com/articles/engine-has-low-power-output
Best, Ken
Mar 18, 2017 at 8:41 AM
