Hello friends,
I need your help and advice.
I have opel corsa c 1.0 2003 Z10xep with 3 cylinder. At cold start works perfect after about 30 mins when engine warm enough, I get the engine warning light with two OBD codes P0300 P0302. Cylinder 2 misfire detected.
I replaced the spark plugs, ignition coil and swapped injectors places.
The misfire is always in Cylinder 2.
Also we checked the timing chain, is perfect.
I did compression test:
Cylinder 1: 145 psi
Cylinder 2: 130 psi
Cylinder 3: 150 psi
Can anyone please help me?
what should I do?
Best regards
Cylinder 1: 145 psi
Cylinder 2: 130 psi
Cylinder 3: 150 psi
what should I do?
Best regards
Oct 20, 2019 at 12:53 PM
