Cooling system
2002 JEEP LIBERTY
150,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
STEELESTORM
  • 23 POSTS
Had my reservoir replace in my car by a garage.Then when I left my radiator was leaking so I replaced it myself.. The thing is my petcock was completely clogged and it had pink in my reservoir n the radiator was filled with green.. I bought what the car called for Zerex go5 hoat.. $224.00 is what he charged me.. Did I get ripped off?
Dec 22, 2019 at 5:33 PM
I'm not sure what you are asking. The coolant you indicated is good to use on this vehicle. However, it only comes in two different colors, red for Chrysler and yellow for Ford. I have never seen it in green. Is it possible that two different colors mixed creating what you see? Could you have purchased yellow that appears to be green?
Dec 22, 2019 at 9:18 PM
STEELESTORM
  • 23 POSTS
Should the garage that replace my reservoir replaced all the the coolant??
Dec 23, 2019 at 5:17 PM
In a perfect world, that is preferred. However, unless requested, most shops only replace what was lost. Do you suspect two different colors mixed?
Let me know if I can help.
Dec 23, 2019 at 10:13 PM
