Cooling system?
2010 JEEP GRAND CHEROKEE
100,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
RICH NORBY
  • 30 POSTS
I have changed the radiator, water pump, thermostat, and heater core and installed a new radiator cap 18 lb. While stationery not driving, at full operating temperature and running engine up over 3,000 RPMs there is no problem. After driving a couple miles when I get back home coolant is being released from the radiator cap running out on the floor. I used a burping funnel to get the air out of the system several times, heater running and blowing hot air. Did this until no more air bubbles come out. Any ideas on why this is happening?
Mar 26, 2023 at 5:04 PM
Is the temperature gauge showing a normal operating temperature? If it is, you may have a faulty head gasket allowing compressed air to enter the cooling system.
Take a look at this link:
Let me know your thoughts.
Mar 26, 2023 at 9:27 PM
RICH NORBY
  • 30 POSTS
Thanks for the info on blown head gaskets, I did the bubble test again watching the bubbles more closely. The bubbles started rising slowly but as the temperature increased the bubbles increased. When the temperature gauge reached halfway the fluid in the funnel erupted. I decided to try the Blue Devil head gasket sealer with the yellow label for $50. Followed the directions on the label. Removed thermostat, drained coolant, flushed system with water. Filled system with water and ran with heater on until blowing hot air to make sure to flush heater core. Drained and refilled with water. I used a cooling system flush (sodium citrate) to clean system. Flushed until no more bubbles and clean water came out. Allowed system to cool several hours before pouring in the Blue Devil sealer. Ran engine for 55 minutes, let cool down and reinstalled thermostat. Refilled system with about 1 gallon of antifreeze. Using the burp funnel again to make sure all air was out of system. As the temperature increased so did the bubbles until the funnel erupted again. Not sure if I should try the sealer again maybe using the blue devil flush instead of the cheaper brand.
Mar 30, 2023 at 10:18 AM
I wouldn't do it again. What I suggest is to check engine compression to see if there is evidence of a weak cylinder or cylinders.
The product you used has a good reputation, so if it didn't help, we may have more than a head gasket issue. However, if we determine lower compression in a couple of cylinders, chances are the head will need to be removed for inspection for a gasket issue or if anything has cracked.
Also, does the temperature gauge indicate it is overheating when the coolant comes out?
Mar 30, 2023 at 7:08 PM
RICH NORBY
  • 30 POSTS
Thanks Joe, I’ll start by looking at the plugs and check compression. The coolant starts coming out when the gauge is only about halfway and about the time the thermostat is opening. The engine seems to be running smooth, I’m not really noticing any rough idle or miss fire. This vehicle belongs to my niece, and she now is telling me that the car has overheated in the past. I’m thinking that it may have warped the head.
Mar 31, 2023 at 7:03 AM
If she overheated it bad enough, absolutely the head could be warped. That should show up when checking compression.
Let me know what you find or if I can help in any way.
Mar 31, 2023 at 10:25 PM
RICH NORBY
  • 30 POSTS
I’ve decided to go ahead and do the head gaskets. I have the alternator, ac compressor, power steering pump, fan shroud, both valve covers off. I also have the air intake unbolted but can’t get it to come off. It’s hitting where the firewall folds out over the throttle body. I removed the throttle body, but it still hits on the throttle body mount. I can’t slide it forward because the heads wrap in front of intake. I’m wondering if I need to take it off at all. I set the timing mark on the crank to top dead center and both cam sprockets are in the wright position. Do I need to remove the timing chain cover to get the cam sprockets off? I wasn’t planning on doing the timing chain. I still need to unbolt the exhaust manifolds, which looks like it won’t be easy. The spark plugs all look good and there is no water in the oil.
Apr 11, 2023 at 3:51 PM
This is a big job. To remove the intake (it is required and is bolted to the cylinder heads) you need to remove the lower motor mount on the right side and then lower the mount until it touches the frame. I attached the directions below.
By chance, were you able to perform a compression test to confirm we have a head gasket issue?
See pics below.
Apr 11, 2023 at 8:48 PM
RICH NORBY
  • 30 POSTS
Thanks for the advice on the air intake removal. I’ll try removing the motor mount. I’m going to go ahead and remove the timing chain cover, just to be on the safe side for cam sprockets removal and inspect guides and tensioners. You’re right about this being a big job.
Apr 12, 2023 at 8:06 AM
Rich,
No problem whatsoever. I hope the directions help. And yes, it can be a nightmare to remove the simplest things. My favorite thing is the use of torx bolts between the engine and firewall that you can't see. LOL
Take care of yourself and if I can help, let me know. Also, let me know how things turn out for you. I'm interested in knowing.
Apr 12, 2023 at 7:28 PM
RICH NORBY
  • 30 POSTS
Joe,
I have the timing mark on the harmonic balancer set to the TDC mark on the block. Does it matter if it’s on compression stroke or exhaust?
Apr 13, 2023 at 7:35 AM
If you are setting the engine timing, the exhaust or compression stroke is controlled by when you set the camshaft timing. The bottom end (crank) still turns the same.
Let me know if I can help.
Apr 13, 2023 at 5:59 PM
RICH NORBY
  • 30 POSTS
Joe,
I finally have the Jeep grand Cherokee back on the road. After the installation of the new head gaskets, the head bolt’s torqued, timing set, everything back together. Started the Jeep and everything sounded great. I checked the oil dip stick, and it was milky, water in the oil, wasn’t there before I started work. I remembered that when I removed the timing cover that water ran out and down into the oil pan. Changed the oil and filter, no more milky oil after running it for a while. I thought all was well until I saw coolant dripping from under the driver's side head near the firewall. I saw in videos that others were using two different torque methods. Discovered that one was for jeeps up to 2001 and the other was for 2002 and later, mine is a 2010. I used the wrong torque settings. Removed the valve covers backed off the head bolts and retorqued the heads again for the 2010 engine requirements. 20 ft lbs twice, then 90 degrees then 90 degrees again. So far, I have no leaks from heads. I took the car for a ride and when I got back coolant had overflowed from the radiator cap. That was second new cap. Found out that jeep recommends using only Jeep radiator cap. My niece has been driving the Jeep for a couple days now and no more leaks or overheating so far. I hope the information on torque required and the radiator cap will help someone out.
Apr 28, 2023 at 9:50 AM
Thank you for the update. I'm glad to know you got it fixed. Anymore, it seems things change from one year to the next. The torque specs are one of the common changes. So, more than likely, your info will help others.
Regardless, I'm glad to know it's fixed. Feel free to come back anytime in the future.
Apr 28, 2023 at 10:36 PM
