Cooling system
2007 SUZUKI IGNUS
16,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
FRANCO123
The radiator fan comes on much more often than any car I have ever owned (lots).
I have put a new thermostat in, a new fan temperature switch, a new radiator and flushed out the system.
Yet, if I drive up a quarter mile hill the fan comes on.
No water is lost and the temperature gauge never goes past half way.
Nearly every time I stop at lights, the fan comes on.
Is it because it is an automatic perhaps?
It is very annoying and worrying.
Thanks, Frank
Jul 21, 2017 at 3:55 AM
It sounds like it can be one of two things, the first is the temperature sensor is off telling the computer the engine is hot or you might have a blown head gasket causing the engine to run hotter. Here is a guide to confirm the head gasket issue:
If that checks out here is the location of the temperature sensor so you can replace it.
Here is a guide that will show you what you are in for when changing it:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Please let us know what happens, we are interested to see what it is.
Jul 21, 2017 at 2:28 PM
