Engine running hot
2004 CADILLAC CTS
183,000 MILES • 3.6L • 6 CYL • AUTOMATIC
CATHYWEST4209
  • 4 POSTS
Replaced radiator, water pump, thermostat, still getting hot. What is left to fix?
Mar 18, 2020 at 1:11 PM
Good afternoon.
I would have a leak down test done to check for a failed head gasket. If compression is leaking into the cooling system, it will run hot.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Did you have this test done?
Mar 18, 2020 at 1:22 PM
CATHYWEST4209
  • 4 POSTS
I don't hear pressure when I removed the resivour cap is that a problem? And why don't I?
Mar 18, 2020 at 1:32 PM
That could be either from a bad radiator cap or you have a leak, such as the head gasket.
You need to have a leak down test done to see if it has a failed gasket.
Mar 18, 2020 at 1:35 PM
Just to add to this, are the cooling fans coming on?
I attached some testing which includes the things you replaced but also a few other things that we need to check.
As the engine begins to get to 210 degrees F the fans should be on high, if not then that is the issue. Let us know what you find with all this info. Thanks
Mar 18, 2020 at 1:39 PM
