Car started overheating out of the blue?
2007 LINCOLN MKZ
164,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
BETHANY1982
Car started overheating out of the blue. Changed thermostat. Checked hoses and radiator and they seemed good. Had car towed to a shop. Shop said its water pump. Had them replace pump and timing chain as well. Took them 2 months. Car still kept overheating. Shop then says its head gasket. My question... isn't there test that can be done before tearing motor apart and if the 2 parts are in same area wouldn't person just change the gasket at same time as pump?
Jan 16, 2023 at 6:58 AM
These are two different jobs, the water pump/timing chain. Yes, there is a test they can do to tell if the head gaskets are blown did, they try that first? Here is the test:
Here is a guide to overheating problem you can check out as well:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
It sounds like they may have missed the problem from the start.
Jan 16, 2023 at 4:20 PM
BETHANY1982
I'm thinking so. The shop didn't state that they did any testing to make sure before diving right in. 1st I was told the water pump. So, I Okay'd the replacement as well ask them to go ahead and replace timing chain since it's right there. After they did this, they test drove it. It still kept overheating. So, then the shop tells me that the header gasket must have been damaged at the same time as the pump and that to replace that it was going to be over 2,000$ because they would have to tear the motor apart again. Now I'm stubborn and decided that I've obviously made my bed with this car so I mise well lay in it. I asked if it would be better just to replace the motor. (Now I had just bought this car and only had gotten to drive it 2 weeks before all this happened which is why I'm being so stubborn because I was determined to not let bad juju beat me) The shop states it would be roughly about the same cost lol. Again, there was no mention of them doing any test to verify if said parts indeed were bad. I wait from August to November for them to locate a motor. (Basically, they parked my car and forgot it. ) So, I have them order motor. Take November and December before they get to the car. Finally last week I'm told the car is done, no leaks or overheats. I go get it. I drove it maybe 1/2 a mile to a store, parked and I let it sit and idol for a min. After idling for almost 10 minutes the car once again overheats. I happened to notice that the overflow cap for radiator was off. maybe blew off from pressure or wasn't threaded on. I take car back. Tell them what happened and how I'm so very not happy. 5,000$ and the problem is still not fixed, even after putting a different motor in!!!
Just received a call from the shop. they believe it's the overflow and cap are stripped threads and isn't staying on.... now this is the original overflow and cap. did I seriously just shall out a butt load money and had 7 months of my time wasted and replaced a bunch of parts that didn't need to be replaced? Is it possible it was the overflow and cap all along? What do I do?
Jan 16, 2023 at 5:13 PM
Yep, a bad overflow cap can cause overheating. That would be a shame, some shops jump the gun and do repairs which they shouldn't due to bad diagnostic work. I would take it to another shop to have them see what's going on while you tell them your story. You might need to go to small claims court for retribution.
Jan 17, 2023 at 2:43 PM
