Okay guys, here’s the breakdown: Cooling fans won’t come on causing car to overheat. Fans will run with AC on. Now I unplugged the wire from the sensor on the bottom of the radiator and both fans come on. I replaced the two sensors going into the block one is a sensor the other a sender I believe? Still having same issue. I did check voltage out of those wires and do have voltage. My question is, could the sensor on the radiator be bad or is it something else? Stumped. Now I have power to the 2 going in the motor but not sure how much there should be. One of them is a single pin connector.
Aug 4, 2019 at 11:13 AM
