cooling fans on radiator
2001 DODGE VAN
169,000 MILES • 2WD • AUTOMATIC
DORIS OWENS
The fans will not come on. I got the relays tested and the fans tested and both are good. what could be the issue?
Jul 26, 2016 at 5:06 PM
WRENCHTECH
  • 20,761 POSTS
I do not know what country you are in, but in the US Dodge does not make a Venture. Chevrolet does though. We also need an engine size to supply you with the wiring diagram that you will have to use to troubleshoot the system.
Jul 26, 2016 at 6:26 PM
DORIS OWENS
I will send it to you tomorrow.
Jul 26, 2016 at 6:35 PM
WRENCHTECH
  • 20,761 POSTS
We get questions from all over the world and often get cars we have never heard of. I do not know if you are in the US or not.
Jul 26, 2016 at 6:41 PM
AL514
  • 5,465 POSTS
He is just trying to help. Tech's need as much information as possible for the correct repair procedure and wiring diagrams.
Jul 27, 2016 at 11:00 AM
CARADIODOC
  • 34,306 POSTS
Hi brother Wrenchtech. Where did you get "Venture" from?
Doris, you also need to specify whether you have the front-wheel-drive Caravan or the rear-wheel-drive full-size "B" van. Those are two totally different vehicles with very different radiator fan systems. Wrenchtech asked you very legitimate questions, including engine size. We need to know what you did not supply because it helps us get to the right information the first time. Wrenchtech is good really good at this.
Jul 27, 2016 at 7:16 PM
