I was recently stuck in traffic and noticed that the temperature was getting high. Twenty minutes later had some steam coming from under the hood because the coolant reservoir was overflowing (seeping out of the cap). I replaced the water pump, changed the belt. I noticed that only one of the two fans for the radiator are turning on. I swapped the relays and fuses for the fans and one will turn on when the car is warm or the A/C is on. There are three relays, one for each fan and one for the fans to run together, from what i understand. Not having another relay that was the same as that one to swap with, I also bought a new relay to replace that one. So ultimately my questions are: Is this normal, for only one fan to be kicking on with the A/C full blast and the car at mid-range temperatures? At what temperature should the two fans turn on? Is there a way to trick the car so I can see if the second fan works before going further with troubleshooting?
Feb 16, 2019 at 10:57 AM
