Cooling fans never turn on
1999 OLDSMOBILE INTRIGUE
137,000 MILES • 3.8L • V6 • AUTOMATIC
SREUBENW
  • 4 POSTS
Tested cooling fan motors they work, tested relays and fuses they work, changed the coolant temperature sensor and engine thermostat, flushed radiator and filled with new coolant. They do not come on with AC, have not yet tried disconnecting coolant temperature sensor, starting to run out of options might have to take it to a shop because I feel like I am chasing a gremlin.
Dec 29, 2017 at 10:16 AM
Good morning
remove the connector from the coolant temp sensor for the computer with the engine running. The fans should both come on.
Let me know the results
Dec 31, 2017 at 6:56 AM
SREUBENW
  • 4 POSTS
Just did the test(twice), both fans did come on both times, im not exactly an expert so what is the purpose of this test?
Jan 2, 2018 at 12:27 PM
checks the complete circuit for the fans.
this indicates either a bad coolant sensor, bad connector or a thermostat issue such as stuck open.
Jan 2, 2018 at 12:49 PM
SREUBENW
  • 4 POSTS
Thank you for the help, local auto parts store wants 40 some odd dollars for the correct connector...
Jan 2, 2018 at 6:37 PM
shop around. that is too much for a connector.
Jan 2, 2018 at 6:40 PM
SREUBENW
  • 4 POSTS
Turns out the gm 3800 engines just run hot commonly hangs out around the halfway mark, the reason the coolant tempature sensor light came on was due to the coolant level sensor reading improper so says Mr. Mechanic dissent exactly make sense to me but cars working good, hope my experience helps somebody, and Thank you everybody for your helpful input
Jan 27, 2018 at 1:48 PM
your welcome
Jan 27, 2018 at 1:57 PM
