I have the car listed above supercharged. I got everything working well on this car and it's close to road worthy but one thing I'm having problems with is the cooling fans aren't kicking on when they are supposed to.
The fuse is good and i will double check the relays to make sure they aren't bad.
Can you provide a diagram of that circuit and how it works please?
Also, any suggestions will help as to how to proceed with troubleshooting. The car sat for a long time, and I've had to do quite a bit to get it ready.
It seemed like the fans were working correctly once but not usually so maybe it's something going out or intermittent.
So, i think I'll double check the relays because that's easy, but if it's not that, what's the next step?
What's the part of sensor that tells the fans when to turn on? And where is it located?
These are the things i need to know if just how to specifically diagnose this problem.
Thank you so much!
Thank you so much!
May 8, 2024 at 9:17 AM
