Hello, the running engine temperature for your vehicle should be a steady 194F. 240 is high, I think that checking around the engine with a temperature gun is a good idea. Being that it's an older vehicle there could be some sludge built up in the coolant system, or the thermostat is sticking. You have 2 coolant fans on this model correct? One of the fans should have a low speed because it has a resistor built into it to regulate current flow, therefore keeping the fan at a lower speed. The engine coolant temperature sensor might be inaccurate as well. Things wear out. Are both fans coming on at 240f?
Really the thermostat does the hard work of keeping the engine coolant temperature where it should be as well as the normal air coming across the radiator. I would check the inlet and outlet of the radiator as well to see if it has a blockage, its in. It's a good idea to change the coolant once and while, I'm not sure what the interval is for your vehicle, but it is one of the most overlooked fluids. I would change it every 30k miles or so.
Service info states that if your vehicle hits a max of 261F you will get a Hot Stop Engine message, so you're getting pretty close there. And you don't want to burn up the head gaskets. If the thermostat is really getting to 240f I would think about having it changed. There is an updated thermostat so I'm going to post this information so if you change it, it doesn't get set in the incorrect position.
In the 1st diagram notice the offset of the pintle. Where there is more space on the top of the thermostat. There is most likely a small hole at the top allowing air to escape when the system is being refilled.
This was part of a Technical Service Bulletin.
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Feb 1, 2023 at 10:16 AM
