Cooling fan not working properly
2000 JEEP CHEROKEE
143,000 MILES
LEN BEAL
I have a new fan, a new relay in fuse box next to A/C and a new temperature sensor in front of valve cover. (inline 6) fan will not come on with A/C and when temperature is 210 on the dash gauge. is their another relay or sensor? if so where, someone said under the headlight on passenger's side. if so how do i access the item? What does it look like?
Thanks,
Len Beal
Jul 22, 2019 at 11:58 AM
Good afternoon,
Did you test for power to the fan motors with a voltmeter or test light to be sure the fan is not the issue?
I attached a wiring diagram for you to view. Check both fuses listed for power on both sides to be sure the fuse block is good.
Jul 22, 2019 at 12:28 PM
