Cooling fan does not come on as should. With A/C on the fan comes on. If I ground at the thermal switch on engine block it still does not work. If I ground the green wire on the relay the fan runs fine. There looks like there is an ECM module in front of the fan relays. Does the thermal sensor run through this module? Any ideas?
May 12, 2018 at 9:49 AM
