How long does the fan run with the ignition off? Normally when the engine is hot, the PCM will run the fan longer just to get the engine cooled down.
Unfortunately we don't have a manual for your vehicle so I am not able to give you much more detail but this is a general rule. However, if it does not shut off then you either have a wiring issue or a module issue. I would not think the fan itself is the issue because it seems to be doing what it is told to do.
Nov 18, 2019 at 5:25 PM
