Cooling fan problems
2005 FORD ESCAPE
126,000 MILES • 2.3L • 4 CYL • 4WD • AUTOMATIC
JAYSHREDSGUITAR
Hello, great site here guys! it is a hybrid two point three liter. i am having an issue with both cooling fans. I have checked so far the fuses and associated relays. I believe I am not getting power out to both the fan motor connectors from relay bank near passenger front by radiator. but I can apply power to both fans and actuate both motors. That doesn’t mean I haven’t made a mistake along the way as this is a complicated system to me. Can you explain how the system functions with the what sensor and A/C on? And what I should be checking how and when? thanks. With A/C on also, no fans working.
Mar 30, 2019 at 9:56 AM
SCGRANTURISMO
  • 4,897 POSTS
This sounds to me like you could have an open in the wiring after the relays in the cooling fan circuit somewhere. In the diagrams down below I have included a factory diagnostic troubleshooting guide. It is pretty straight forward and simple, but it will require you to use a multi-meter. I have included a link below if you are unfamiliar with how to use one.
Please go through the guide down below and let us know what you find out.
Thanks,
Alex
2CarPros
Mar 31, 2019 at 1:10 AM
