Before tearing into the circuit, run power directly to the fans to make sure they are functional. If they are, keep in mind there are three relays. I just took a look and from what I'm seeing, fan relay 1, located in under the hood in the engine compartment, must work for the other two to get power. I would start there.
I attached the wiring schematic below for you. I had to cut the pic in two to make it readable. I did overlap the two so you can follow from one to the next.
I hope this helps. Let me know if you have questions.
joe
See pics below.
Feb 28, 2025 at 8:39 PM
