I have been having an issue with this car since i bought it. Drives strong. Fan always stay on high then shuts off then comes on high randomly. Usually with these cars it's a sign the pump is about to fail. Left it alone. Changed the coolant temperature sensor in the head. Nothing changed. Does not overheat. One day it gave the yellow light for temperature. So, i towed it in. No codes. Changed the pump and thermostat. Now it does not heat, stays around 220-230f if left idle for a long time. Fan still comes on while idling, at high, sometimes at low around 212 or so. Is there a relay for the fan that could be stuck? I left it running for 7 minutes and now the scanner shows 419f. Measured the radiator hoses and it's at 112 and 90f.
Feb 10, 2023 at 6:56 AM
