Pulled the engine a while ago to rebuild it and when we put it back in and started it, we noticed that when the vehicle exceeded temperature the fan would fail to kick on. Replaced the fan control module, the coolant temperature sensor and the capacitor that goes on the end of the fan control module and the fan still fails to kick on. I did notice that when we unplugged the coolant temperature sensor while the car was running the fan kicked on to the highest setting. I want to add that the A/C compressor does not work and does not have a belt. But that's an issue for a different day unless that is causing the problem.
Apr 21, 2023 at 5:06 PM
