Cooling fan
2014 CHEVROLET CRUZE
33,000 MILES • 1.8L
JAMAL EYLIA
There was a water leak coming on the top of the water outlet. I took the car to a mechanic shop to be fix.They replace outlet part, after replacing the part light engine is on and the cooling fan keep running. Please, I will be appreciated if someone can help me to resolve this issue.
Jun 25, 2019 at 5:07 PM
SCGRANTURISMO
  • 4,897 POSTS
If your Malfunction Indicator Lamp (MIL) or "check engine" light is illuminated could you please pull the Direct Trouble Code(s) for us. Here is a link below that will explain how to do it if you are unfamiliar with how to do it. You will need a code reader to do this.
Please go through this guide and get back to us with what the code is.
Thanks,
Alex
2carPros
Jun 25, 2019 at 9:12 PM
