Hello and welcome to 2CarPros. If the fans are not operating properly it can cause then A/C system to build too much pressure where the refrigerant blows out the compressor valve. Repair your fan issue so you can properly diagnose the A/C system if there is still an issue. The hot gases that run through the condenser needs to be cooled down by the fans.
If that's okay this guide will help us see whats going on also I have included the cooling fan wiring diagrams so you can see how the system works. Check fuse # 46 and 7
Check out the diagrams (Below). Please let us know what happens.
Aug 23, 2019 at 9:00 PM
