it is running a bit over half way. i have replaced both head gaskets, the radiator, the water pump, thermostat, and temperature sensor. i checked the cooling fans and they seem to be working fine. i have flushed the coolant system three times with prestone flush and removed block drain and refilled with fresh antifreeze, distilled water, and a corrosion inhibitor.. it builds up pressure on radiator hoses quickly upon a cold start, but i have checked for bubbles in the coolant and there are none. it's about 80 degrees outside and after a short drive the engine seems quite hot to me. is this normal?
Apr 8, 2021 at 1:24 PM
