If it is coming from behind the fan pulley, it's the water pump. I recommend not putting anymore sealer into it. Also, I recommend flushing the radiator and engine block before reinstalling a new pump.
First, take a look through this link. The second picture shows the weep hole I am referring to. I am 99.9% sure that is where the leak is. Note that it is behind the pulley. Also, a sealant won't fix that problem. It is caused by a seal issue or the bearing is going bad.
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
Here is a link that shows in general how one is installed:
https://www.2carpros.com/articles/water-pump-replacement
______________
If you look at pic 1, i attached an exploded view of the water pump on your vehicle. I circled the pump and highlighted where I believe the leak is coming from.
Next:
Here are directions specific to your vehicle. Pics 2 and 3 correlate with the directions.
Community 12 Create Quote
2003 Ford Truck Explorer 2WD V6-4.0L VIN E
Procedures
Vehicle Engine, Cooling and Exhaust Engine Water Pump Service and Repair Procedures
PROCEDURES
Water Pump - 4.0L SOHC
Removal and Installation
1. Drain the engine cooling system.
2. Remove the cooling fan.
3. Remove the accessory drive belt.
4. Remove the components in the order indicated.
Part 1 Of 2
pic 2
Part 2 Of 2
pic 3
5. To install, reverse the removal procedure.
6. Fill and bleed the cooling system.
Item 10: Coolant Pump Installation Note
1. Use metal surface cleaner and a suitable plastic or wooden scraper to clean the sealing surfaces.
2. Install a new coolant pump gasket.
__________________________________________
Let me know if that helps. Also, let me know if you need help or if you have any questions. I have to be honest with you. I feel you should try to flush the system. Here is a link that explains how that is done.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
I hate the alumi - seal products because they melt down to stop the leak. As a result, it isn't uncommon for them to plug other things, specifically the heater core. I suggest you only use such products in an emergency.
Let me know how it goes for you or if you need anything.
Merry Christmas (in 15 minutes) LOL I hope you have a good one.
Dec 24, 2019 at 8:46 PM
