Coolant water, how can I drain it and put it back?
2005 MERCEDES BENZ C200
160,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
ABOOTHMAN
  • 8 POSTS
Hi Sir.
The drain plug is leaking, and i have to replace it or put in a new washer and the coolant is new.
How can I drain it and put it back?
Thank you
Nov 1, 2023 at 1:17 PM
BORIS K
  • 836 POSTS
The easiest way to drain the cooling system is to raise the vehicle in front so that you can access the drain plug. Fit a clean rubber pipe or similar to the drain pipe.
Loosen the drain plug and drain the coolant into a clean container
Once fully drained remove the old drain plug and fit a new one.
Refill the cooling system with the recovered coolant.
A good video:
https://youtu.be/5o6UYo-WfDs?si=B7TriQDhT7Bpsxf5
How to drain and fill:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Cheers, Boris
Nov 2, 2023 at 8:01 AM
