Where is the Coolant Temperature Sensor located for replacement?
2013 DODGE DURANGO
135,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
CRYSTAL HEARN
MEMBER
1 POST
FOLLOW
I am trying to locate the coolant temperature sensor on my vehicle and I can't locate it.
Nov 19, 2023 at 2:17 PM
CARADIODOC
CERTIFIED EXPERT
Here's a drawing that shows where it is. Be aware temperature sensors have a very low failure rate because there's just one component inside them. Problems in this circuit are much more likely to be caused by wiring and connector terminal problems.
