Just so I understand this, you don't have that code now? That code is why you replaced the sensor and now the temp sits where it is in the picture and the cooling fans come on immediately even on a cold engine?
If so, you have a faulty sensor. The fans are coming on immediately because that sensor is telling the PCM that the engine is hotter then it is. However, if the engine is actually running at that temp then we need to look into the cooling system however, I suspect it is the sensor.
Let me know if this is correct. Thanks
May 8, 2020 at 7:03 PM
