So my car I noticed the coolant was cold after driving for a good hour etc., with very little pressure built up as well. I’m not loosing coolant though, as I’ve checked it several times after sitting overnight and it’s always in the same place. I’ve recently replaced the water pump along with the thermostat mainly because it was the original one and the pump bearing went out so I wanted to do it all together. What could this be from or causing this issue? My inside temperature gauge is always in the middle also. Also the lower radiator hose is cold while upper is hot. Heater hose inlet is hot along with outlet hose.
I was planning on purchasing a new radiator cap for my tank to just make sure it wasn’t that causing the issue.
Also in the event I need to drain it completely where and how do you drain the block completely?
Nov 4, 2020 at 9:51 AM
