Can I get a coolant temperature sensor wiring diagram?
2010 CHEVROLET MALIBU
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
RONAROLL
  • 12 POSTS
I am replacing the coolant temperature sensor. The electrical plug in was also bad so I bought a new one. The existing wires coming into that plug were both yellow. I have to cut this to connect the new plug. I am not sure which wire goes on which side of the sensor. I have a 50/50 chance on getting this right. what if I don’t?
Jul 12, 2022 at 11:10 PM
BORIS K
  • 836 POSTS
The two wires leading to the ECT sensor are actually yellow and tan, see diagram below.
The sensor is a simple NTC resistor so the wiring can be attached either way.
Hope this helps.
Cheers, Boris
Jul 13, 2022 at 2:38 AM
RONAROLL
  • 12 POSTS
Thanks. What is the best method for splicing the wires? They are kind of hard to get to. Also do you know what the connection is under the sensor? It's about 4” long and light blue. And is just lying there loose. It has some king of ring, clip or whatever it’s called.
Jul 13, 2022 at 9:19 PM
BORIS K
  • 836 POSTS
I prefer using insulated crimp joints, see picture below. You insert each side wire into the joint, crimp it with a suitable tool and then apply heat to reduce the heat shrink to provide a waterproof joint.
A good video
https://youtu.be/i5LBf19MqPk
Could you please provide us with good, clear picture of the connection in question?
Cheers, Boris
Jul 15, 2022 at 5:00 AM
