So I recently had to replace my timing belt and on this model, you have to remove the thermostat housing which also is the home of the coolant temperature sensor. The SUV will run when the connector to the coolant temperature sensor isn't connected but when it is connected it causes it not to start.
I replaced the thermostat, coolant temperature sensor, and gasket. I've replaced the coolant temperature sensor twice thinking that maybe it was a defective new part from AutoZone. I recently bought a new connector and spliced it on and still got the same results of a no start when connected. I also get the code p0117 now.
I've had my timing rechecked by a licensed mechanic thinking that may be the issue. Everything checked out fine there. I replaced the fuel pump prior to the timing belt being replaced also. It starts fine without that sensor being connected so I assume this wouldn't be the cause of the issue.
So can anyone think of any reason as to why the connector keeps the SUV from starting when it is connected? It starts up fine without the coolant temperature sensor being connected. Any help is greatly appreciated! Thank you
Jun 26, 2019 at 3:43 PM
