Coolant temp sensor gauge maxed out?
2004 CHEVROLET SILVERADO
320 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DALTONTROTTER
  • 9 POSTS
I had to replace a gasket for my exhaust manifold and unplugged my coolant temperature sensor sensor and after I was finished I plugged it back in. I turned the ignition on and the coolant temp gauge was reading maxed out even tho the truck was cold. I unplugged the sensor and same reading on the gauge. Truck is throwing a p1258 overheating code and dash is saying limp mode overheating. I inspected the wires all the way to the y and they look good. I replaced the sensor and nothing changed.
Jan 10, 2026 at 7:38 PM
So it sounds like the electrical connector to damage or one of the pins in the connector is pulled out of the connector so the connection of the gauge (PCM) is open which will cause this problem, please remove the connector and use a flashlight to inspect the pins.
P1258 - Engine Protection Mode Active
This is normal when the coolant temperature sensor circuit is open. If it looks okay let do a hard reboot of the PCM/Gauges which can help reset the system. Please go over this video.
https://www.youtube.com/watch?v=INiDRO5A5MY
Please go over this guide and get back to us. Please upload a short video in your response of the problem, so I can see what's going on :) Ken
Jan 11, 2026 at 10:51 AM
DALTONTROTTER
  • 9 POSTS
Ok I did what the video showed I’m going to let it sit for a few minutes but the pins in the plug look good and the sensor looks good to
Jan 11, 2026 at 12:34 PM
DALTONTROTTER
  • 9 POSTS
I just plugged the sensor back in and put the negative terminal back on and it did not fix the problem
Jan 11, 2026 at 1:22 PM
Yep, something must have got pulled on the wiring you are going to have to test the wiring from the sensor to the PCM. Here is a guide and the wiring diagrams so you can run the test. Also, check the engine harness grounds, if one of the grounds is off it will cause this problem.
Check out the images (below). Let us know how it goes
Jan 12, 2026 at 11:28 AM
