After reaching operating temperature my coolant temperature keeps going up, the water pump was replaced before the issue began due to water pump failure, since then the thermostat has been replaced, the coolant system has been flushed, new coolant added. However, the system is ranging around 221 degrees on a 190-degree thermostat according to live data thru OBDII from the ECT.
Aug 22, 2022 at 3:46 PM
