coolant system over pressurizing
2003 MITSUBISHI ECLIPSE
100,000 MILES • V6 • MANUAL
ROGER HEINTZ
Replaced radiator, thermostat. The system seems to be over pressurizing even after running just a few minutes. What could cause this to happen and how would we fix? thanks
Mar 21, 2019 at 2:07 PM
CARADIODOC
  • 34,306 POSTS
The most likely cause is a leaking cylinder head gasket. That would allow combustion gases under pressure to sneak into the cooling system. The radiator cap will limit pressure to 15 or 16 psi, then you'll see excessive bubbling in the reservoir.
Usually the additional symptom is you have to add coolant periodically. The best test to verify a leaking head gasket involves drawing air from the radiator, while the engine is running, through a glass cylinder with two chambers partially-filled with a special dark blue liquid. If combustion gases are present, the liquid will turn bright yellow.
Here's a link to an article that describes this test better:
Mar 21, 2019 at 6:42 PM
