Coolant system
2015 FORD ESCAPE
40,000 MILES • 1.6L • 4 CYL • TURBO • AUTOMATIC
BRUCE CHARTRAND
This connector leaks coolant, car remains on H engine overheat warning even if sitting overnight! I am hoping to find out what is the name of the part I need to replace. It is the top L shape connector in this image. Also, will this correct my high temperature warning or will I have to replace a sensor? If so what sensor? Thanks
When coolant is added it pretty much flows right out the back of that L shape connector. Goes to a smaller hose!
Sep 16, 2018 at 3:33 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Can you use your phone to upload a picture to see what component you are talking about? That would help.Thanks for using 2CarPros.
Danny-
Sep 16, 2018 at 8:48 PM
BRUCE CHARTRAND
Here you go. It would not upload with the original post.
Sep 16, 2018 at 10:07 PM
DANNY L
  • 5,648 POSTS
Hello again.
I have attached a picture and believe it is #5 or #6 and circled in red (hard to tell from your picture). I believe it is #5. They are called the "Transmission Fluid Cooler Coolant Control Valve Inlet Hoses". Hope this this helps and ask any other questions if needed. Thanks again for using 2CarPros.
Danny-
Sep 16, 2018 at 11:23 PM
BRUCE CHARTRAND
Definitely in the place of #6. Thanks a lot!
Sep 17, 2018 at 8:22 AM
DANNY L
  • 5,648 POSTS
You are welcome!
Danny-
Sep 17, 2018 at 11:00 AM
