Coolant sensor location
2014 FORD TRANSIT
64,000 MILES • 2.5L • 4 CYL • AUTOMATIC
VONDA OSWALD
I am trying to locate where the cylinder head temperature sensor.
Apr 1, 2019 at 6:42 PM
Welcome to 2CarPros.
I attached two pictures to help you locate it. Let me know if this helps.
Apr 1, 2019 at 7:16 PM
VONDA OSWALD
Thank you so much. I have been searching everywhere on the internet and always got the run around. So is this easy to replace?
Apr 1, 2019 at 7:44 PM
Welcome back:
It just screws out. You shouldn't have any trouble. Here are the torque specs for when you are installing the new one:
Installation
1. Note: Make sure that a new component is installed.
Torque : 106 lb.in (12 Nm)
Please note that the torque specs are inch pounds and not foot pounds.
If you run into trouble, let me know. I try my best to help you from here.
Apr 1, 2019 at 8:01 PM
VONDA OSWALD
When i ran the code reader on the van the same code came up three times. does that mean there are three different things wrong?
Apr 1, 2019 at 9:39 PM
Welcome back:
No, if it's the same code, it will be related to one issue.
Let me know if you run into trouble.
Apr 2, 2019 at 6:51 PM
