Coolant reservoir problem
1996 FIAT PUNTO
155,000 MILES • 1.1L • 3 CYL • 2WD • MANUAL
TAMAS.SZATMARI
I am having a small issue over here with my daily driver. Two days ago I got my front bumper repaired because it was dislocated so might as well I wanted to do the basic routine checks inside the engine bay. We took a look at the engine oil, coolant etc. My father came to give me hand with the coolant level because I was not sure. Unfortunately, there was a storm soon coming so he closed the hood and by the time I came back to finish up the things he said it is all good. Unfortunately, he forgot to put the coolant cap back on and I have been driving around the whole day yesterday without having it on. At the end of the day before I went inside the garage I heard something weird under the hood so I immediately went to take a look at it. The coolant was boiling inside the reservoir and I just noticed that the cap was on the car’s battery. (Luckily I did not lose it.) So I waited until the coolant cooled down and I put it back on. This morning I had to take it to work and the car’s heating was not working. I had no time to check under the hood because I was in a rush. What could be the problem? Is it serious? Today I am definitely taking it to a repair shop just in case.
Thank you for your answer in advance.
Dec 4, 2018 at 10:48 PM
TAMAS.SZATMARI
Update: the cooling fan does not seem to work at all and I was advised to change the thermostat. I would still be happy to receive a professional answer just in case if iti s something more complicated than that.
Thank you in advance!
Dec 5, 2018 at 2:39 PM
If the fans are not working, chances are the thermostat is not the issue. I would recommend checking fuses, relays, and the fan motors. If you told me the engine never warmed up, I would suspect the thermostat, but since the fans are not turning on when it over heats, I suspect something different.
Also, if you have no heat today, make sure the coolant is not really low. As far as leaving the radiator cap off, keep in mind, when the cooling system pressurizes, the boiling point is increased. Without the cap on, the coolant will boil at a lower temperature.
An easy way to determine if it is a thermostat is to see if the vehicle overheats at highway speeds. If it does not and only overheats in stop and go traffic, then I suspect the fan not working is the cause. If it still overheats at highway speeds, then suspect the thermostat.
Here are a few links that may be helpful:
https://www.2carpros.com/articles/how-an-engine-thermostat-works
https://www.2carpros.com/articles/replace-electric-fan-motor
Dec 5, 2018 at 8:32 PM
