Coolant not flowing to heater core/heater does not work?
2007 CHRYSLER 300
76,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
EXTRABAD8
  • 8 POSTS
The heater has been giving me issues for a while now. At first the heater wouldn’t put out heat unless driving down the road. Now it doesn’t work at all. A/C and blower and blend door work fine. I thought it was a clogged heater core because one line was warm and the other cold. I pulled both lines, and the heater core wasn’t clogged at all. Water flowed through easily both ways. Then I put a jumper hose connecting both heater core hoses and no coolant is flowing through. I also changed the thermostat and bled all of the air out of the system. Still has no coolant flow through those heater core lines. The engine runs great, no overheating and upper and lower radiator hoses get hot.
Dec 20, 2022 at 11:55 PM
I have a feeling the oil cooler is plugged and preventing coolant flow to the heater core.
Engine coolant flows into the oil cooler from the heater return tube and exits into the water inlet tube. If the cooler is clogged (I've seen it before) coolant can't flow through the heater core.
I attached a pic below showing the cooler. It is right near the oil filter. In the pic, the number 3 points at the filter.
Let me know what you find.
See pic below.
Dec 21, 2022 at 9:22 PM
EXTRABAD8
  • 8 POSTS
I think you are right. I pulled both lines off of the oil cooler and put a piece of tubing connecting the two lines and started the car and the heat worked perfectly. I ordered a new oil cooler, and it should be here tomorrow. I’ll let you know.
Dec 22, 2022 at 12:29 AM
That is the problem. I've seen a few but the issue seems to be becoming more common.
Let me know if that takes care of the problem.
Take care and I hope you have a great Christmas.
Dec 22, 2022 at 9:32 PM
EXTRABAD8
  • 8 POSTS
Well, I found the issue. The oil cooler wasn’t allowing any coolant to flow through it. I replaced the oil cooler and now it works like brand new, and the engine runs cooler as well. Thanks for the help.
Jan 5, 2023 at 8:09 PM
Thank you for the update. I had a feeling that was the problem. I'm just glad to know you got it fixed.
Feel free to come back anytime in the future if you have questions or need help. You are always welcome.
Take care and I hope you have a great 2023.
Jan 5, 2023 at 9:05 PM
DEEPAK WALIA
Resurrecting an old thread. I am currently having this issue with my son's 2009 300 touring. I wanted to know that if I unhook the pipe and bypass the cooler, do I first have to drain the cooling system? I don't want to unhook the pipe and have the entire contents of the cooling system spill out.
Thanks.
Jan 7, 2025 at 7:25 PM
Yes it is best if you drain the coolant out before working with the heater hoses. Upload images or short video if you have any problems so we can better help you.
Jan 9, 2025 at 10:29 AM
