coolant leaks inside the car and passenger side
1996 OLDSMOBILE 88
196,345 MILES
MATRIX33
coolant leaks into the car on my passenger side the the cooling dosent stay in the in the tank I put it in both spots into the tank and into the radiator but my windows in the car still get foggy how can I fix this
Jul 31, 2013 at 10:02 AM
CARADIODOC
  • 34,306 POSTS
That's a typical symptom of a leaking heater core and a plugged air conditioning condensate drain tube. Replacing the heater core involves discharging the air conditioning refrigerant. That can be very dangerous. Beyond that replacing a heater core is a real big job and not one for the average do-it-yourselfer to tackle. If you think you're up to the challenge, get a copy of the manufacturer's service manual and read through the pages of instructions, then decide if you want to attempt it.
Jul 31, 2013 at 10:12 AM
MATRIX33
So there wouldn't be a hole in the hose
Jul 31, 2013 at 10:39 AM
CARADIODOC
  • 34,306 POSTS
There aren't any hoses inside the car, just metal pipes, or, in the case of a lot of GM vehicles, plastic pipes.
Jul 31, 2013 at 11:15 AM
MATRIX33
Ok the heater core making it leak into the car was well right
Jul 31, 2013 at 11:43 AM
CARADIODOC
  • 34,306 POSTS
The heater core is the only thing that can leak inside the car.
Jul 31, 2013 at 11:49 AM
