Coolant leaking coolant from driver side bottom of radiator
1998 CHEVROLET MONTE CARLO
132,234 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
DSKRILL
The car runs regular temperature but low coolant light flashes and stays on. Then when I park after driving coolant is dripping from bottom right side of radiator. Why?
May 23, 2018 at 12:07 AM
HARRY P
  • 2,292 POSTS
Well if it is coming from the radiator, then the radiator is probably cracked and needs to be replaced. The best way to test it is with a cooling system pressure tester. Here is a general how-to guide: https://www.2carpros.com/articles/radiator-pressure-test
You can borrow that tester from AutoZone, Advance Auto, Oreilly Auto Parts, or even Pepboys (I think) for free with a deposit. Just fill the system first, then pump it up, and follow the leak.
Let us know what you find and we'll help you more from there.
May 23, 2018 at 4:24 AM
