2003 Pontiac Montana 69000 miles coolant leaking and brake fluid leaking.
At first coolant leaking at beneath of engine after inspection at car shop. I added coolant leaking stop and stopped leaking for one year. Recently I found it leaking fast and accumulate on the engine.
It looks like water pump leaking or a worn seal on the water pump shaft can leak coolant. Is it possible fix by myself?
Recently brake fluid is decreased suddenly when out temperature low at 6 to 10F. I do not know where it leaking. I think that the brake fluid leaking may be caused by accumulated coolant on the top of the parts near the engine and water pump. But I do not know exactly why. I checked 4 tires brake lines not leaking. And it looks leaking at similar place with coolant leaking. Is it possible to fix it by myself?
Thanks for your comment!
Mar 4, 2015 at 11:38 PM
