I have the car listed above sc1 where it’s got very low miles. I drive about 50 miles a week maybe once a month 100 miles. so I had my radiator replaced last year no problems. Then just a week ago my coolant light came on it wasn’t overheating same indicator spot was it on, air flow was normal heat, by the time I got home I was almost empty. I bought some more coolant put it in and thought that was it drove about 1 mile and the coolant light came back on. so I got home and put cardboard underneath the car in the areas that I read should be a place it might leak. Its coolant looks normal, by the way no oil in it. It was on the middle of where the radiator is maybe a couple of inches down it was hard to tell after it rained. I’m hoping to get ideas to do it myself because my mechanic isn’t able to see me until January 6th and that’s only to dialogue it. It’s not making in engine noise sounds or smoke out of the exhaust it runs pretty much like normal. That’s what’s so frustrating is when I read others that have a similar issue it just isn’t the same problem or isn’t any close to mine. I do know that the oil change place said I needed to replace my gasket on the oil something it was $169.00 he said all it does is cause you to lose oil faster. other than that I’ve replaced almost every part that matters.
Dec 28, 2020 at 7:44 PM
