What are the installation procedures for replacing Ford part # 1F1Z8N030BA
2003 FORD TAURUS
102,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DARKHORSEREDMANE
  • 6 POSTS
Coolant leak at "connector" which is mounted into lower intake manifold connected coolant reservoir return line to engine.
Jul 25, 2019 at 6:08 AM
Good morning,
Can you attach a picture of the connector you referred to in the post?
Jul 25, 2019 at 6:25 AM
DARKHORSEREDMANE
  • 6 POSTS
Here they are.
Jul 25, 2019 at 6:30 AM
That is an elbow for the heater hose off the intake. Is that correct? It looks like it presses into the manifold and has a hose on the other side.
Hard to see from a distance with the picture.
Jul 25, 2019 at 6:53 AM
DARKHORSEREDMANE
  • 6 POSTS
You are correct it is an elbow, but it is the return/overflow line from the coolant reservoir.
Jul 25, 2019 at 6:58 AM
Okay, what is the issue with the elbow? Is it leaking? Broken? That is a rare part to fail unless there is severe corrosion in the cooling system.
Jul 25, 2019 at 7:05 AM
DARKHORSEREDMANE
  • 6 POSTS
It is corroded with pin holes leaking coolant, I have remove the old part which was actually loose from the corrosion. New part has been ordered, I just want to make sure I install it properly.
Jul 25, 2019 at 7:08 AM
Okay, did you get all of it out of the manifold?
Like I said before, it presses into the intake manifold. When you get the new part, you will need to tap it into the manifold until it bottoms out.
I would also have the cooling system acid flushed to get rid of all the corrosion. Water pump impeller issues are common for systems with this corrosion.
Jul 25, 2019 at 7:11 AM
DARKHORSEREDMANE
  • 6 POSTS
Greatly appreciate your time and attention in responding. If I may ask one more question. Should any sealant or lubricant be applied before tapping the part in?
Jul 25, 2019 at 7:13 AM
No, that will make it difficult for installation and you may damage the connector. The most I would use is a little vaseline.
You are welcome.
Always glad to help.
Jul 25, 2019 at 7:21 AM
DARKHORSEREDMANE
  • 6 POSTS
Much appreciate, thank you!
Jul 25, 2019 at 7:25 AM
You are welcome.
Jul 25, 2019 at 7:28 AM
