Coolant leak under the radiator
2008 BMW 323
250,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
JADEN55
I have a coolant leak because underneath my car. There seems to be a leak right underneath the radiator. so I’m just wondering if it’s a corroded plastic on the bottom of the radiator or it could be housing nearby?
May 5, 2021 at 2:43 PM
It is hard to know for sure but it may just be a crack in the radiator.
However, here are some guides that will help figure out what the part is that is leaking:
https://youtu.be/W8kra65m15c
https://www.2carpros.com/articles/radiator-pressure-test
Once we have a better idea as to where the leak is coming from we will have a better idea what to do. I would suggest cleaning the area off with a rag and a spray parts cleaner and then pressure testing the vehicle.
Please run through this info and let us know what you find. Thanks
May 5, 2021 at 7:47 PM
