Coolant leak
1998 CADILLAC DEVILLE
179,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
HARDHATKATT
Coolant leaking from cylinder head https://drive.google.com/open?id=0B8rWLeDg5ijjandIT29MMVF4Q1U
Link is to video I took. Is this a expansion plug?
Apr 10, 2016 at 7:46 PM
CJ MEDEVAC
  • 11,004 POSTS
Looks like it's coming out of a freeze plug
Video angle does not show the full plug
Is it rusted out in the middle?
Or
Has the freeze plug popped out of it's hole?
The medic
Aug 18, 2019 at 10:05 AM
CJ MEDEVAC
  • 11,004 POSTS
Expansion plug- freeze plug same thing!
The medic
HARDHATKATT
There is literally nothing there, just an open hole. I have looked and looked but can't find any info on a freeze plug for the Northstar any idea what size plug I need?
CJ MEDEVAC
  • 11,004 POSTS
I know this is a stupid question
Is this an emergency?
Do you have time to do a permanent take stuff apart and install a new one?
Would a temporary fix (do it right soon) work for the present time?
If you can get a hand and a wrench in there
Can really tighten this up good
Can get the right size
Other stores have these too
See this link
Http://shop.advanceautoparts.com/web/partsearchcmd?storeid=10151&catalogid=10051&pageid=parttypelist&suggestion=&actionsrc=form&langid=-1&vehicleidsearch=-1&vehicle_39340=1998+%3a+cadillac+%3a+deville+%3a+4.6l+281ci+v8+fi+vin%3a+y&vehicle_444699=2009+%3a+chevrolet+%3a+impala+ls+%3a+3.5l+213ci+v6+fi+vin%3a+n&vehicle_49556=2001+%3a+gmc+%3a+savana+1500+%3a+5.0l+305ci+v8+fi+vin%3a+m&searchterm=freeze+plug+-+rubber&searchedfrom=header
Whachu think?
The medic
HARDHATKATT
I was looking at these earlier the only problem is that when I plug in my car info to find a size it doesn't produce any results. I suppose I could just measure the hole and buy accordingly?
CJ MEDEVAC
  • 11,004 POSTS
Roger that
It's the back plate and rubber that must fit in the hole
The closer, the better
If it's hard to measure
You might use your imagination and try bottle/ jug caps/ sockets (my favorite)/ anything round that fits the hole that could be measured once removed
The medic
CJ MEDEVAC
  • 11,004 POSTS
When you install these
Sometimes it's ezier to sorta "pre-tighten" it so that it "drags" the hole as it enters
Since there is no way to "back-hold" the assembly, it will spin if installed loosely
The friction from the "drag" will keep it from spinning as you continue to tighten
The medic
