As far as I can tell, my car does not leak coolant while the car is off, but once I turn it on it begins to leak coolant. It seems to only leak when the reservoir is filled and leaks until the reservoir is empty. I say this because the car does not overheat, so I assume there is still some coolant in the system. The leak is coming from beneath the car close to the oil filter. I have attached a video of the location of the leak. Can you help me fix this leak? I am not sure exactly what needs to be replaced/repaired.
Dec 2, 2024 at 7:06 AM
